RobAmour
Jan 04, 2019Apprentice
Restricting SSID to a specific AP
I have one SSID broadcast from all AP's, I'd like to create a second SSID associated with one of the AP's and a third SSID associated with the other AP. Is this possible through the Insight App / In...
schumaku
Jan 06, 2019Guru - Experienced User
While it's possible to add additional wireless SSIDs for either the same or for a dedicated VLAN, assigning these to just specific WAC isn't possible in Insight or Insight Pro.
Aside, this would be better suited with the Insight Network Management System community section.
