FINITEREX
Dec 15, 2020Guide
Support for GS510TLP
Can anyone tell me if the GS510TLP is support by Insight Management, I've added mine to the portal but shows as "not accesible".
schumaku
Dec 15, 2020Guru - Experienced User
Insight does allow to discover most switches, by far not all are Insight/Remote cloud manageable. as of writing, the GS418TPP / GS510TLP / GS510TPP are not.
Netgear seems to be in progress adding select newer switch models to the Insight/Remote cloud manageable list. No idea about any plans for this group of models.
FINITEREX
Dec 15, 2020Guide
That's a shame, good little switches... would be great if there was a firmware update to enable insight management... don't really want to shell out for new switches when these do such a good job.
TBF it would be nice if there was a firmware upgrade since a year ago!
