joshduguid999
Aug 04, 2018Aspirant
Audio-over-Ip on NETGEAR m4300 Switch mDNS & SAP
Looking for help, since apparently Netgear charges $100 just to talk to support for a switch I purchased less than 3 months ago.
Configuration is as follows:
m4300-96x switch stacked with two other m4300-28G switches. The m4300-96x is the stack master. Using most current firmware.
Issue is this: mDNS and SAP won't function for anything plugged into the 96x switch. Anything I plug into the other two switches in the stack functions perfectly. I've baffled every person i've talked to, every configuration item I can find is exactly the same on all ports in the switch stack, and since it IS a switch stack, the overall configuration for IGMP, snooping and queriers are identical.
mDNS and SAP are critical to my network design: audio and video over IP using Dante, AES67 and SDVoE. Can anyone think of ANY reason why these won't work on only one switch in the stack?
Any help, or experience with this issue would be greatly appreciated.
Cheers,
Josh D.
Hey,
So what I had to do to get IGMP working properly was configure things under the IP(routing)/Multicast settings. Make sure the global configuration is on, the IGMP global configuration is on, and configure your VLAN under interface settings. That should get IP based IGMP working for you.
Under "switching/multicast" is only L2 IGMP, which might be why you're having issues with Dante.
- LaurentMaNETGEAR ExpertHi Josh
Sorry about this issue. We are going to fix it.
After 90 days of phone support, you are entitled with lifetime chat technical support. But don't worry, our Tech Support team is coming to you using private message.
Yes, we fixed mDNS issue, entirely, years ago in our M4300 switches with IGMP - and our brand new M4300-96X shall be no exception. Stay tuned!
Regards,- atianAspirant
Hi Josh,
we tested it in lab and couldn't see your issue. could you post the techsupport file?
you can go to the GUI: Maintanence-> Export-> HTTP file export, select techsupport file, and click the 'Apply' button.
- twinlakeschurchAspirant
We are also having problems with Dante Controller mDNS messages. Dante controller is nearly un-responsive when using the m4300, when I plug in an old unmanaged switch, it works flawlessly. We are also hearing poping and clicking in the dante audio stream on the m4300.
We are using two M4300 one as primary dante and one as secondary. FW ver 12.0.6.6.
- joshduguid999AspirantCan’t help with the mDNS, cause it’s not working yet. Popping and clicking sounds like a clocking issue, which is probably a QoS issue.
The only thing on these switches are a half dozen Dante devices ruinning a total of 10 chanels of audio. I have tried QoS both in the default configuration as well as Audante recomened settings.
I have spoken with Audante and they are convinced it is the switch. As soon as I use a non-smart 100Mb/s switch it all functions correctly. Long term I need to send this audio between buildings so the dumb switch is not a long term solution.
Any word on IGMPv3 support? I am also unable to get IGMPv2 to work successfully with Dante.
Thanks for the help!!!
Yes the two switches are connected together, but they are using seperate VLANs 1155 for primary and 2155 for secondary dante audio. 155 is for my control network, Shure Axients, BSS BLU-806 control network, etc. I have many more devices to connect to these switches and will eventually need IGMP and to connect to the rest of my infastructure as I would like to distribute Dante audio campus wide. The switching infastructure is all netgear and has plenty of bandwidth.
I would love to hear about how you got IGMP working properly.
Hey,
- kohdeeAdministrator
Hi! Based on this community post, we created this. Hopefully it helps you configure your NETGEAR switch with Dante devices.
https://kb.netgear.com/000060205/M4300-Configuration-Guide-for-Dante-Audio-Devices
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
