chris-c
Feb 02, 2026Tutor
Issues onboarding WBE718 access points in Australia
Hi Folks, I am having issues onboarding several WBE718 access points using Engage. The onboard button is not available (greyed out/disabled). My site region is set to Australia but if I create ...
schumaku
Feb 02, 2026Guru - Experienced User
Hi Chris,
From what I see WBE710 / WBE718 Firmware Version 11.7.0.12 including support for Canada, Australia, New Zealand, Singapore dates back from early July, 2025.
Is the location on the AP itself (locally!) set to Australia, too?
These are common question not on with Netgear Engage, but also with Netgear Insight. The device location must match the intended operation location, otherwise adding it to e.g. Netgear Insight won't be possible.
If this does not resolve the problem, don't hesitate to contact Netgear Support please. Stay tuned for some "fun" with the L2 support 8-). Good luck!
-Kurt.
chris-c
Feb 02, 2026Tutor
Thanks for the reply Kurt,
I can upgrade firmware and onboard in the UK region site, until the point that Engage checks the region of the AP. It's AU region so doesn't onboard correctly.
In the Australian region, Engage doesn't even give me the option of onboarding. Engage says that I can't onboard this model of switch in my region. Given this different behaviors between regions it seems to me like an Engage issue rather than a WBE718 firmware issue?
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
