chris-c
Feb 02, 2026Tutor
Issues onboarding WBE718 access points in Australia
Hi Folks, I am having issues onboarding several WBE718 access points using Engage. The onboard button is not available (greyed out/disabled). My site region is set to Australia but if I create ...
chris-c
Feb 02, 2026Tutor
Thanks for the reply Kurt,
I can upgrade firmware and onboard in the UK region site, until the point that Engage checks the region of the AP. It's AU region so doesn't onboard correctly.
In the Australian region, Engage doesn't even give me the option of onboarding. Engage says that I can't onboard this model of switch in my region. Given this different behaviors between regions it seems to me like an Engage issue rather than a WBE718 firmware issue?
schumaku
Feb 04, 2026Guru - Experienced User
chris-c wrote:Engage says that I can't onboard this model of switch in my region
Yes, as it appears. Had a chance to file a support ticket with Netgear already?
- chris-cFeb 04, 2026Tutor
I managed to follow up with Netgear support and it is in fact a limitation of the current Engage software. This has been fixed in the next (upcoming) Engage update. If anyone from Australia is in a similar situation, Netgear do have a beta version of Engage that can get you out of trouble. Alternatively, you can wait for the next update.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
