cresur
Jun 08, 2023Follower
M4250-10G2XF-PoE++ SFP port & AGM734 not working
Hello, I have a few M4250-10G2XF-PoE++ switches deployed with AGM734 SFP modules installed in Port 11 & am not having any luck getting the ports to work. I get no connection with the device plugg...
schumaku
Jun 08, 2023Guru - Experienced User
Just for the future reader (and probably not applicable to cresur here as he is using the port 11 when I read this correct).
Extended Datasheet M4250 Series for AV Line Managed Switches related to the AGM734 M4250-16XF (XSM4216F) - it does fits into M4250 SFP+ and SFP interfaces, and supports AGM734 on its ports 1 to 12 only.
Hard to say what does disable the port affected. Probably some Auto-DoS DanielZhang ?
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
