MasashiSawata
Jan 05, 2026Aspirant
[MSM4310/VSM4320C] How to routing the mDNS packet between different VLAN.
Hi everyone I try to setup MSM4310 and VSM4320C with multiple VLAN for divide control, video signal and so on. On the other hand, I would like to enable the mDNS communication between the VLAN fo...
- Jan 06, 2026
Hi, the packets won’t naturally cross VLANs. To allow devices on different VLANs to discover each other, you need an mDNS reflector or gateway—either a feature built into your managed switch (sometimes called “mDNS Gateway” or Bonjour Gateway) or a small server running software like Avahi configured to forward mDNS between VLANs. IGMP alone won’t help because it’s meant for managing multicast traffic within a VLAN, not for linking separate VLANs, so using a reflector or proxy is the way to make mDNS work across multiple VLANs.
bettyparker098
Jan 06, 2026Initiate
MasashiSawata
Jan 06, 2026Aspirant
Thank you for your replies.
I will try to adapt the Gateway such as RP60X for managing the mDNA across the VLAN.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
