vincentpierard
Dec 08, 2023Aspirant
NDI + Dante
Hi everyone,
I'm new here.
Has someone ever tried to run NDI and Dante concurrently in the same VLAN using the Video NDI5 with Dante, Q-SYS, or AES67 audio profile template?
The description of the template states: Use this template to connect the switch to NDI Version 5 (RUDP) video devices and cameras. Audio Dante, Audio Q-SYS, and Audio AES67 templates can be used at the same time in the same VLAN.
This concerns a small TV studio where video is strictly NDI and audio is strictly Dante.
All devices are connected to a AV M4250-40G8XF-PoE++ (GSM4248UX) network switch (40x1G PoE++ 2,880W and 8xSFP+ Managed Switch). Currently there is one NDI VLAN and one Dante VLAN. All NDI devices support NDI5 (RUDP) and later. For the sake of simplicity and also because some devices that should be connected to both VLANs as well as to a third network with Internet access) don't have enough NICs, I'd like to try to merge everything into the same VLAN. But I'm quite doubtful it would work without any issue. So if anyone has an experience to share, I'd be grateful to read it.
Cheers!
Dear vincentpierard
Don't hesitate to contact the Netgear Pro AV Design Services team for free design support and implementation assistance for AV networks on any scale. Strongly encouraged - they do a brilliant job! Keep us posted about the findings and conclusion please.
-Kurt
- vincentpierardAspirant
Dear schumaku
Thank you very much for these very instructive tips. I was not aware of their existence. I will contact them and will share the results.
Vincent
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
