muzicman82
Jun 23, 2020Aspirant
M4200 -> M4300 Multicast Configuration (for NDI / Dante)
Hi all,
I am not having any problems currently, but I wanted to run the config by this group and see if there's anything I'm missing or if any tweaks are in order...
I have a M4200 with several NDI devices connected. Currently, port 10 is uplinked to port 25 on the M4300, which will serve as the main switch.
I haven't created any additional VLANs, so everything is operating on VLAN1. As far as I can tell, I have querier enabled on only the M4300, snooping enabled on both switches, and the querier address is 1.1.1.1 on the M4300 for highest priority, and 2.2.2.2 on the M4200. I also have Fast Leave enabled but the detail below doesn't show this (what show command would report this?) Is this all correct?
This is for the M4300:
(M4300-28G) #show igmpsnooping querier detail
Last Querier Querier VLAN ID Address MAC Address IGMP Version ------- ---------------- ----------------- ------------ Global IGMP Snooping querier status ----------------------------------- IGMP Snooping Querier Mode..................... Enable Querier Address................................ 0.0.0.0 IGMP Version................................... 2 Querier Query Interval......................... 60 Querier Expiry Interval........................ 60 VLAN 1 : IGMP Snooping querier status ---------------------------------------------- IGMP Snooping Querier VLAN Mode................ Enable Querier Election Participate Mode.............. Enable Querier VLAN Address........................... 1.1.1.1 Operational State.............................. Querier Querier MAC Address............................ bc:a5:11:16:82:cb Operational version............................ 2 Operational Max Resp Time...................... 10
This is the M4200:
(M4200-10MG-PoE+) #show igmpsnooping querier detail
Last Querier
VLAN ID Address IGMP Version
1 10.101.1.107 v2
IGMP Snooping Querier Mode..................... Disable
Querier VLAN Address........................... 2.2.2.2
Operational State.............................. Disabled
Last Querier Address........................... 10.101.1.107
Operational Max Resp Time...................... 11Finally,
I haven't gotten to it yet, but I will be adding maybe 3-4 Dante devices to this network. Is there a compelling need or reason to separate this into a different VLAN? Or, can I configure QoS as I normally would for Dante on VLAN 1 and not negatively affect the NDI traffic?
Thanks!
- NeilSNETGEAR Expert
Hi...
Using 1.1.1.1 and 2.2.2.2 as querier addresses are not a concern as the addresses can be anything you wish, ie., they are not actual IP adreses, but used as part of an election process. Since there can only be a single querier active in the network, and if (as in your case), multiple
queriers are configured, this can trigger an election process. The current active querier will be the switch with the lowest address configured in the querier field.The M4300 is the primary querier, so in the event of any M4300 downtime, the M4200 would then become the primary IGMP querier, etc.
In order to view Fast-Leave information, the following commands can be used for example:
#show igmpsnooping 1
#show igmpsnooping fast-leave (at port level)Regarding running Dante and NDI devices on the same VLAN, the best practice recommendation would be to create a seperate VLAN for the Dante devices.
There is a kb available for this available at: https://kb.netgear.com/000060205/M4300-Configuration-Guide-for-Dante-Audio-Devices
Please let us know if you have any further questions.
- muzicman82Aspirant
Thanks for the info... a few follow up questions:
- Am I correct to leave IGMP Snooping Querier Mode to Disable for the M4200 (but enabled on the M4300)? This does give me exactly one querier. I thought there should not be more than one querier on a network, or is that recommendation just for simplicity of not having to properly set up election priorities? I mean, in this sort of environment, if the querier is down, the switch is down and I have more problems....
- Also, I though that with the IGMP proxy mode enabled, there actually isn't a querier elected?
- One recommendation for NDI is to disable QoS? How is that done on these switches, and if I were to setup a VLAN for Dante, I'd need to disable for NDI VLAN and configure QoS for Dante VLAN (I've done this before).
Hi,
To answer.
1. Practicality suggests having more than one querier in the event of any failures on the network.
So can make sense to have both switches enabled as querier, but each with higher/lower IP values in the event of an election process.
2. Yes, by configuring all switches (and/or Routers) as IGMP proxy queriers, no designated IGMP querier is elected.
3. QoS isn't enabled by default on either switch model, so no need to specifically disable for NDI devices.
QoS can then be enabled for all Dante devices on the new VLAN.
I hope that helps answer your questions.
