davidh1207
Oct 13, 2026Initiate
VLAN Routing - AES67 and Dante
Hi, I have two VLANS set up on a system with 16 switches. I am using the Video with AES67 Audio profile for my main VLAN VLAN 95). This VLAN has all of the Crestron control and NVX devices on it ...
davidh1207
Netgear Tech support recommended I have just one VLAN that would accommodate all the protocols that I need. I am currently using the Video with AES67 on my main control VLAN which also has my NVX encoders and decoders on it. I also have a Dante Audio VLAN with all of my Dante equipment.
One step at a time - I changed the main VLAN to use the Video with Dante profile since Dante is AES67 compliant (from what I understand). I'll give it a day or so to make sure everything is still working as it was. If all seems well I will move the ports that are on the Dante VLAN to the Video with Dante VLAN and see if everything works and if I can see my NVX AES67 audio streams on the Dante equipment.
I also have a colleague that recommended just having a flat network with 1 VLAN of the appropriate profile. He has done some bigger systems but the one I am working on has 16 switches, all linked with 10G fiber links and a variety of equipment including Crestron control, Crestron NVX video/audio streaming, a Crestron NVX Director, Shure Dante, Symetrix Dante, Dante amplifiers, and probably a few other things I overlooked.
I'll post more after the next step...
Best,
David
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
