l-vicente's avatar
l-vicente
Follower
Oct 07, 2025
M4350 core duo, stack & dante AES67.
Hello everyone.
We want to secure our audio infrastructure (private lan) by creating redundancy at the level of the two M4350-12X12F core switches, which are responsible for managing and distributing the other M4300-52G switches, linked to dante and green go devices.
We have set up four VLANs, including one for Dante (which will need to support AES67 in the future).
What i found on documentation :
It seems inadvisable to create a stack of two core switches when using Dante AES67, and it does not appear possible to create an MLAG for the M4350 versions.
What is the best solution for creating redundancy at the level of my two M4350 core switches? Is it the implementation of a VRRP for the VLAN IP addresses?
Thank you for your feedback.
Laurent
1 Reply
  • schumaku's avatar
    schumaku
    For MLAG, there is no way around stacking two M4350 imho.
    For better advise, strongly suggest to contact the Netgear ProAV Design support team, the community isn't the ideal place for design support.
    LaurentMa​ svp.
ProSupport for Business
