shejialun
May 01, 2024Aspirant
Abnormal delay in pinging the gateway ip through WAN 2.5G port.
Hello When my SXR80 WAN 2.5G port is connected to the ISP's gateway, the computer is connected to the LAN through the cable, and then the latency is very unstable when pinging the ISP's gateway ip o...
shejialun
Jul 14, 2024Aspirant
Hello FURRYe38
I used CAT6A cable and the problem persists.
The ISP modem is a ZTE, model ZXHN-F4600T.
Also have a Netgear R7000 as an uplink gateway with the same problem.
However only the 2.5G port is experiencing problems.
schumaku
Jul 14, 2024Guru - Experienced User
Both the R7000 as well as the ZTE ZXHN-F4600T have only GbE interfaces, no MultiGig or 2.5 GbE capable. Does the SXR show a GbE link speed on that SXR 2.5G WAN interface?
- shejialunJul 15, 2024Aspirant
Hello schumaku
I don't understand what it means to show GbE link speed on the SXR 2.5G WAN interface.
Does it mean selecting port 1 (2.5G) or port2 (1G) in the WAN settings?
What is MultiGig? What does it do? Shouldn't 2.5G interfaces be downward compatible with Gigabit ports in general? thanks.
