AlexW22's avatar
AlexW22
add a wired device to LAN
Hi there ,
Can anyone tell me how to move a wired connected device to another LAN?
I want to move a device from LAN 1 to LAN 3, but the assigned ip address is in LAN 1 range.
And I want this device in LAN 3 be cause I have another VLAN assigned to it.
I am using the SXK80 Orbi Pro.
Cheers,
Alex
  • plemans's avatar
    If you log into it using the browser, go to Advanced---->advanced setup----->vlan/bridge settings.
    there you should be able to change which port is associated with which vlan and the specific client isolation/network association for that vlan.
    • AlexW22's avatar
      AlexW22
      I do not want a lan port assigned to a vlan, I want a move a wired connected device moved to another lan, in this case lan 3, which has the iot vlan assigned to it. If I assign a whole lan port to vlan, everything connected to it will also be on the vlan.
ProSupport for Business
