cdonston's avatar
cdonston
Follower
Nov 04, 2022
Backhauling Orbi SRS60 system
I currently have the Orbi main router SRR60 with two SRS60 satellites.  I have recently built a barn approx. 200' away from my home.  I ran a network cable to the barn.  I would like to add an additional SRS60 in the barn and connect it to the network cable as well to improve speed and to make it hardwired.  Is this possible with these models.  I have done some research and read about "wired backhauling" and think that might be the solution.  Just not sure if my models are compatible.
1 Reply
  • plemans's avatar
    Yes your models support a wired backhaul.
    Wired backhaul is really a perfect setup when you're running that far as the wireless backhaul won't reach.
ProSupport for Business
