Jiheffe2
Apr 13, 2018Aspirant
Brand new SRR60 router stuck on solid white ring...
So I just unpacked my OrbiPro system. The router starts up (blinking white ring) but then stops with a solid white ring forever... It does broadcast the default WiFi SSID (the one on the sticker) and...
- Apr 16, 2018
The Orbi Pro router does come in router mode by default. As per the fine documentation (SRK60 User Manual) p.11 - "Router LED ring: Solid white. The router is resetting to factory default settings." As there is no success with the initial start-up nor with the reset button action, I'm tempted to say we have a hardware issue here, your router (or the complete kit) might require replacement. Depending on your market you handle this with your reseller or etailer, or direct with Netgear (mainly North Americas) as this is a DOA.
schumaku
Apr 16, 2018Guru - Experienced User
- Jiheffe2Apr 16, 2018Aspirant
schumaku wrote:Depending on your market you handle this with your reseller or etailer, or direct with Netgear (mainly North Americas) as this is a DOA.
Thank you schumaku. I do agree with you, I also RTFM and understood it was stuck somewhere :mansad: I even tried 30-30-30 (you never know) but no success. The whole stuff is packed again, ready for return to Amazon tonight.
That being said, I asked a refund, not a replacement, as the limited functionality of the "Employee network" is a showstopper to me.
I'm considering buying a consumer Orbi (not a pro) instead. I will have only one SSID + Guest, but it is a real mesh system.
