PAfarmboy
Feb 23, 2022Initiate
Can’t block devices SRR60, Insight App
I bought and installed this network for its promise of parental controls, but this isn’t working. Never has (been using for 8 months). Devices I know are active appear as “Disconnected” When I slide...
schumaku
Feb 24, 2022Guru - Experienced User
Not aware any Orbi Pro, including the ones built around the SRR60 or the SXR80 base stations ever came with a promise like any kind of parental controls.
PAfarmboy wrote:
Devices I know are active appear as “Disconnected”.
PAfarmboy kids might have figured out on how to use random MAC addresses on their iPhones, Droids, ... if you think you catched them, they will delete the WiFi connection, reconfigure the WiFi connection ... there it comes, a new device identity. A rat race you can't win.
PAfarmboy wrote:
When I slide the Resume/pause button from green to off on a specific client, nothing happens. The devices (“clients “) still can access the Wifi.
Is there another setup step required for this to work?
Network trash without these device-blocking controls.
Permitting the really active device (not one with an identity from the past) is affected, well possible we face a bug here. BruceGuo
Rodent
Aug 21, 2022Tutor
When I bougt the SRR60, I was informed that I could have great Parental Controls through the NG portal Genie. Somewhere along the way the internet version - and the app - has vanished - which pretty much left me (and others it seems) hanging...
Anoying!!
- DaneAAug 21, 2022NETGEAR Employee Retired
The SRR60 does NOT support Parental Controls. Parental Controls are NOT even indicated in the SRR60 data sheet here.
DaneA
NETGEAR Community Team- RodentAug 21, 2022TutorHi DaneA
I know that the product as it self doesn't have any Parental Control functionality. But before I bought the SRR60 I contacted the seller on the issue, and he referred me to Genie. My need for parental control greater now, but now Genie is no more, and that's annoying.
Kind regards
Rodent- JeremyKissockFeb 26, 2023Aspirant
Hi, did you figure it out? I'd be very interested to know as your story mirrors mine.
Thanks for your advice.
