PAfarmboy
Feb 23, 2022Initiate
Can’t block devices SRR60, Insight App
I bought and installed this network for its promise of parental controls, but this isn’t working. Never has (been using for 8 months). Devices I know are active appear as “Disconnected” When I slide...
Rodent
Aug 21, 2022Tutor
When I bougt the SRR60, I was informed that I could have great Parental Controls through the NG portal Genie. Somewhere along the way the internet version - and the app - has vanished - which pretty much left me (and others it seems) hanging...
Anoying!!
DaneA
Aug 21, 2022NETGEAR Employee Retired
The SRR60 does NOT support Parental Controls. Parental Controls are NOT even indicated in the SRR60 data sheet here.
DaneA
NETGEAR Community Team
- RodentAug 21, 2022TutorHi DaneA
I know that the product as it self doesn't have any Parental Control functionality. But before I bought the SRR60 I contacted the seller on the issue, and he referred me to Genie. My need for parental control greater now, but now Genie is no more, and that's annoying.
Kind regards
Rodent- JeremyKissockFeb 26, 2023Aspirant
Hi, did you figure it out? I'd be very interested to know as your story mirrors mine.
Thanks for your advice.
- Elija11May 10, 2023Aspirant
I read this article. I think You put a great deal of exertion to make this article. I like your work.
