Seif
Aug 01, 2021Aspirant
Can I connect SRS60 or SRR60 (AP mode) as additional satellites to an RBR850?
Hi, I planning to buy an RBK852, and I happen to have an SRS60 and an SRR60. Can I connect them to the RBR850 as additional satellites? Please advise if you know for sure if I can do so. Than...
Aug 01, 2021Guru - Experienced User
Not sure if the Pro series is compatible with the Home 8 series systems. I was told my 30 series isn't...
The SRR in AP mode could be however it would be a separate SSID name using different channels and would not integrate into the MESH system of the 8 series system.
- DaneAAug 02, 2021NETGEAR Employee Retired
Seif,
The Orbi Pro WiFi 5 devices which includes the SRR60 and SRS60 are not compatible to work with any Orbi Home devices such as the RBK852 and RBR850.
Also, the Orbi Pro WiFi 6 devices which includes the SXR80 and SXS80 are not compatible to work with any Orbi Home devices such as the RBK852 and RBR850.
DaneA
NETGEAR Community Team
