Becksi
Dec 07, 2023Aspirant
Orbi RBK 853 - additional satellites
how can I add new satellites into an existing configuration, if the new satellites were used previously in another network. Although it’s the same type, the existing network doesn’t include them. When logging in into the new satellites, they seem to be connected to the router, but are not implemented into the network. The lock in page says “not connected”, resetting them did not help.
- I have turned all the satellites off and then connect the new one first. Afterwards I turned on the other ones.
FW the same version on the RBS and what's on the current RBR?
What firmware version is on the current running system?
What model are these RBS? 850 series?
- BecksiAspirantYes, they have all the Same firmware: V7.2.6.21
It’s All the Same Series RBK 853.- FURRYe38Guru - Experienced User
IF all is loaded with same version of FW, then using the RBRs web page to Add Satellite to the system should work. I recommend turning OFF all other currently connected RBS while you get the incoming RBS connected.
How many RBS are deployed?
