Asato
May 02, 2019Tutor
Can I setup multiple Orbi Pro Systems on the same Orbi Account?
Do I have to create a separate online account for each Orbi Pro system that I have in different locations?
You don't have to create a seprarate account,
You may login Insight using your netgear account from insight.netgear.com or download Netgear insight APP from App Store and Google Play,
and add multiple OrbiPro device in your Insight account.
- JohnC_VNETGEAR Employee Retired
Hi Asato,
Welcome to our community! :)
If you are the original owner of the device, then, it should be registered under your name and the same account to avoid duplicates and confusion when it comes to warranty claims.
JohnCarloV
NETGEAR Community Team
The [My]Netgear account is for device registration, support, et all - it's not a "Orbi Account" used specifically for a single installation or the like.
- evan2NETGEAR Expert
- Apr 16, 2020Retired_Member
