DDignam
May 06, 2020Aspirant
Can the router backup be restored to a replacement system
I just purchaed an Orbi Pro Router with 2 Satellites. Unfortunately I'm in the UK and it came with power adapters with continental plugs. I've used adapters to get things up and running. A replacemen...
DaneA
May 06, 2020NETGEAR Employee Retired
Welcome to the community! :)
You can restore the backup configuration to the replacement Orbi Pro WiFi System that you will receive.
DaneA
NETGEAR Community Team
- DDignamMay 17, 2020Aspirant
Sorry for the delay in responding, took a while to get replacement units with UK plugs, and then had to wait for a good time to take the internet away ...
Anyway, worked like a charm, thx !
