DDignam
May 06, 2020Aspirant
Can the router backup be restored to a replacement system
I just purchaed an Orbi Pro Router with 2 Satellites. Unfortunately I'm in the UK and it came with power adapters with continental plugs. I've used adapters to get things up and running. A replacemen...
DaneA
May 06, 2020NETGEAR Employee Retired
Welcome to the community! :)
You can restore the backup configuration to the replacement Orbi Pro WiFi System that you will receive.
DaneA
NETGEAR Community Team
DDignam
May 17, 2020Aspirant
Sorry for the delay in responding, took a while to get replacement units with UK plugs, and then had to wait for a good time to take the internet away ...
Anyway, worked like a charm, thx !
