patricktong
Mar 25, 2023Aspirant
Compatibility of SXS30 and SXK80
Hi, all, can I connect SXS30 as satellite to the SXS80 as extension of my setup SXK80 network? Thanks.
patricktong wrote:
Hi, all, can I connect SXS30 as satellite to the SXS80 as extension of my setup SXK80 network? .If you mean the SXR80 router, it looks like it:
Which Orbi Pro routers and satellites are compatible? | Answer | NETGEAR Support
For better advice, try the appropriate section:
- BruceGuoNETGEAR ExpertYes. They are compatible.
