Davide_1
Nov 17, 2022Aspirant
Configuration with ORBI PRO SXK30 dual router
Good morning, I'm looking for help setting up my ORBI router, currently the network infrastructure is set up as follows: MODEM/ROUTER - ISP (to which I don't have access) IP: 192.168.1.1 Ethernet...
Nov 17, 2022Guru - Experienced User
Davide_1 wrote:
Good morning,
- MODEM/ROUTER - ISP (to which I don't have access) IP: 192.168.1.1
Ethernet connection- AP/Switch (D-link DIR-626L) IP: 192.168.1.99 < Maybe swap this out for a 1Gb LAN switch. (GS-105 or 108)
Ethernet connection- ORBI router IP: 192.168.2.1 (connected to IP: 192.168.1.2) <If you want the modem router to be the host rotuer, then configured AP mode on the Orbi Pro system.
- Davide_1Nov 17, 2022Aspirant
Thank you for the answer.
So some more consideration:
Ethernet connection AP/Switch (D-link DIR-626L) IP: 192.168.1.99 < Maybe swap this out for a 1Gb LAN switch. (GS-105 or 108)Unluckly I can only manage the device but not changet becouse is serves as anaccess point for another apparment
Ethernet connection ORBI router IP: 192.168.2.1 (connected to IP: 192.168.1.2) <If you want the modem router to be the host rotuer, then configured AP mode on the Orbi Pro system.So If i understad correctly i can:
- Keep it as a router an do a doble NAT
- Set it as an access point, in this option i'll be able to create different Vlan (device and IOT)?
- FURRYe38Nov 17, 2022Guru - Experienced User
Ethernet connection AP/Switch (D-link DIR-626L) IP: 192.168.1.99 < Maybe swap this out for a 1Gb LAN switch. (GS-105 or 108)Unluckly I can only manage the device but not changet becouse is serves as anaccess point for another apparment <Ok.
- Keep it as a router an do a doble NAT <Yes, however you chose do this, you may want to sue the Modems DMZ for the SXR router in this mode.
- Set it as an access point, in this option i'll be able to create different Vlan (device and IOT)? <I believe so. I haven't ran AP mode on mine in awhile and don't remmber what features are supported in AP mode.
I'll try and i post the solution.
I've also posted an image of the "infrastructure".
