SCOGPASTOR
Dec 01, 2021Follower
Connecting a 3rd Orbi Outdoor Satellite
Hi... I have the Orbo Pro Tri Band SRR60 Router and 6 SRS60 satelites..all working great.... I added 2 Orbi outdoor satellites RBS50Y...havent had any problems either... however i can not add a third Orbi outdoor satellite for another building the church has ....
Have I reached the limit???
I have comcast gigabit service...
first time i have ever asked a question... sorry if not enough info...
1 Reply
There isn't a hard limit on how many you can attach. I've seen 8 attached but it can start impacting performance negatively.
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
One trick that is used is one a satellite is synced, power it off to setup additional unit. Then once the new one is synced, boot up the ones you'd powered off. You might be able to try that.
