askvictor
Jul 26, 2022Initiate
Connecting two satellites by ethernet?
I'm setting up a new Orbi pro system. We have two offices separated by about 15m, and want to have one network across them. I have the router (SRR60) connected in one office, and want the two satelli...
Jul 26, 2022Guru - Experienced User
I would try both options.
reason why is that version does support daisy chaining.
but if the connection between the 2 satellites is sketchy, the hardwired connection might be a better option.
Sadly, you don't really know until you test it.
And it should auto-negotiate if its hardwired in to use that connection.
