camberna
Oct 24, 2021Aspirant
Cycling error--despite cycling
Full disclosure: I've been trying this on my own for the last 36 hours, so I haven't yet searched the message boards that intensively because I'm ready to pull my hair out. I'm thus posting my issue ...
Oct 27, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
- cambernaOct 28, 2021Aspirant
Thanks so much for the reply! I ended up removing the entire power strip from the wall before cycling back on modem > router > satellite > extenders, and that ended up doing the trick. Something had stayed plugged in with a hidden power strip that should not have. Thank you for the response!
