DoctorC
Dec 23, 2021Aspirant
Does Netgear Orbi have built in modem as we need to connect directly to office internet connection
hello all, We have a new office opening and an internt conenction provided already. I want to order an Orbi SXK80B4 but need to know if the Orbi primary unit has a built in modem in case the internt...
Dec 23, 2021Guru - Experienced User
The SXK80 doesn't. But I wouldn't recommend one with an integrated modem anyway. For more than 1 reason.
reasons:
1. If its has an integrated modem, the isp controls the firmware updates. Not a good thing from a business perspective as the ISP rarely updates
2. If you switch isp's, you have to get a different router if they aren't compatible
3. If you upgrade services/speeds, the modem might not be rated for it and you'd again have to buy a new router with it
4. It might not be compatible with your isp. You need to check with your ISP to see what gateway's are compatible.
- DoctorCDec 29, 2021Aspirant
thanks, i didnt expect it would have as normally they dont and the ISP in this case Colt, should provide the modem as part of their NTE and present a RJ45 connection to us the customer.
I am trying to get Colt to confirm this but its proving painful to get the details from them.
- plemansDec 29, 2021Guru - Experienced User
I've never even heard of Colt as an ISP so I've got no idea what they use for standard modem/gateways.
Colt are prevelant in the UK and some parts of Europe. Most ISP's should deliver to their NTE with modem as standard, with an ISP Router being optional.
