mokeb's avatar
mokeb
Does OrbiPro Wifi 6 (SXK80) support WAN link aggregation?
Looking to use SXK80 with MB8600 modem using link aggregation on the orbi's wan port.  Does this model (specifically the SXR80 router) support that connection?  If so, how is the SXK80 configured for wan link aggregation?
  • BruceGuo's avatar
    BruceGuo
    NETGEAR Expert
    Hi
    Go to ADVANCED -> Setup -> WAN Setup
    Choose the WAN port as “Port 2(1G)” and APPLY
    Then, go to the switch setting and enable LAG on port 2 and 3.
    Bruce
    • mokeb's avatar
      mokeb
      I tried these steps previously without success when connecting to mb8600 modem with link aggregation enabled.  Have you been able to get it to work?
      • BruceGuo's avatar
        BruceGuo
        NETGEAR Expert
        Hi
        SXK80 only supports static LAG on WAN port. What's LAG mode the modem "mb8600" supports?
        Bruce
ProSupport for Business
