thomatrix
Oct 20, 2021Aspirant
Far from advertised speeds (SXR80/SXS80)
Hi all,
new here, so be nice :)
I have the SXR80 router with two SXS80's and I am not getting anywhere near the speeds advertised. Even when I connnect to the router and stand right next to it I only get 280 - 300 Mbps down and half that up via Wifi.
I have a 1000/1000 Mbps line and get around 920-940 Mbps up/down cabled. The Ookla Speedtest result that test the speed of the internet connection via the Insight app confirm these numbers - so the line in is just fine...
I have mainly tested speeds using my iPhone 13 Pro Max but have also tested using other devices. Wifi results are consistently hovering around the sub 300 Mbps mark.
Here some additional info:
Hardware Version SXR80
Firmware Version V3.3.0.122
GUI Language Version V1.0.0.417
Not sure what else to share - any clues here in the community? Anyone else having this issue?
Thanks!
How is the orbi wifi configured? Using single SSID name and PW?
Is the mobile phone connected to the SXR or SXS when speed testing? Should be connected to the SXR for speed testing and accuracy
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?What connection rates are you seeing on the iPHone with WiFiSweetSpots app loaded on the phone while connected to the SXR?
thomatrix wrote:
Hi all,
GUI Language Version V1.0.0.417Not sure what else to share - any clues here in the community? Anyone else having this issue?
Thanks!
- thomatrixAspirant
Just used the standard config - Single SSID and PW
When testing I am standing 1 meter (3 feet) away from the SXR and have turned off the 2x SXS to be 100% sure that I am connected to the SXR
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.Right now I would like to understand why the speeds are so low when I am right next to the router (just to tackle one issue at the time :) )
Any Wifi Neighbors near by? If so, how many?We live in an area with very little wifi "polution" from neighbors. I have not yet tried changing the settings and assumed that when I stand next to the SXR and can only find our own SSID it should deliver expected speeds?
- blunderdome85Apprentice
Note - this is all assuming that you're using Ookla (speedtest.net) to get your test results.
I had similiar results with my SXK80 when I first set it up. Ookla was reporting ~300mbps up/down on mobile devices connected to the main router when standing just a few feet away. Internet connection itself is ~1000mbps up/down and ethernet speeds were as expected.
What I found was that Ookla seemed to be the issue. In other words, the test results were inaccurate.
Start by trying a file transfer from a wired device on your LAN to your mobile device and see what speeds you get. This should eliminate any issues with the testing servers/internet connection and give you a good baseline for what your wifi connection is capable of. I found that the same devices that were reporting 300mbps down on Ookla were getting ~800mbps during LAN file transfers.
If things look good there start trying other speed tests and see how consistent the results are. What I found was that while Ookla was reporting ~300mbps, fast.com and Google's speed tests both reported much higher speeds in the ~600-700mbps range.
Finally, try some of the other servers available to you via Ookla. Ultimately what I found was that the test servers it kept connecting me to were bottlenecking my testing. When I tested a few other nearby servers I ended up mirroring the results I was seeing using the other testing platforms. - MstrbigMaster
thomatrix wrote:Hi all,
What speeds do you get using the ionternal GUI or app speed test?
- thomatrixAspirant
thomatrix please take the valid blunderdome85 hints into your testing efforts, e.g. check the speed yon your local network, or use an alternate speeed test app and cloud platform please.
Any progress on this?
thomatrix wrote:
Hi all,
Thanks!
