dvrickjones's avatar
dvrickjones
Follower
Jul 07, 2024
Frequent disconnects since latest update (SXR30 & SXS30)
Since the latest firmware update 4.3.4.200, my Orbi Pro WiFi 6 Router frequently disconnects and I can no longer access my SXS30 Mini Satellite. Any suggestions?  I have switched to 5G but it has the same issues.
1 Reply
  • FURRYe38's avatar
    Does the front LED on the SXR turn pink when this happens?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
ProSupport for Business
