SRSmith's avatar
SRSmith
A6100 and Windows 10 disconnects frequently
Model A6100 WiFi USB Adapter 802.11ac Dual Band - (got it now?)
Software:  genie version 1.0.0.12
Driver version: 1030.3.831.2015
Network router is configured for WPA2/AES
Connection looks great in system tray until trying to utilize any network resourse - then adapter goes to "Connected, no internet access"
If I disconnect then reconnect, everything works for a while, usually stays, but always breaks upon restart.  This is not acceptable.
Is there a solution?  I've tried looking and looking and looking without success.
TIA -Mark
  • My apologies for not following this thread more closely.  This somehow got away from me - but the issue seems to be resolved, and unfortunately I'm not certain what may have fixed it.  Windows updates I imagine, but as to which one, I can't tell.
