cecltd
Apr 04, 2020Tutor
how to connect SRR60 remotely using Insight app?
Hi, I have 2 Orbi routers: RBK40 & SRR60 in different locations. It's fine for me to connect RBK40 remotely using Orbi App. I understand that I can't connect SRR60 remotely using Orbi App which is for home products. The right app I should use is Insight App. But I would like to know how to remotely connect to SRR60 using Insight App? It seems Insight App is just listing out the registered Netgear products.
Thanks a lot
Welcome to the community! :)
Let me share the articles below:
How do I set up my Orbi Pro WiFi System to work with Insight?
How do I discover, add, and register switches, access points, and Orbi Pro WiFi Systems in Insight?
Manage Orbi Pro Remotely with NETGEAR Insight - Small Business Mesh WiFi Just got Easier
Hope it helps.
DaneA
NETGEAR Community Team
1 Reply
- DaneANETGEAR Employee Retired
Hope it helps.
DaneA
