Mstrbig
Feb 12, 2024Master
I can no longer log into SXK80 system using 192.168.1.1
I have always been able to login to 192.168.1.1, or any of the orbilogin methods.
Recently I am no longer able to access any of the Router or 2 satellites by going to 192.168.1.1, 192.168.1.2, or 192.168.1.3.
However I can access and login to the following:
192.168.1.1/hidden_info.htm or 192.168.1.2/hidden_info.htm
192.168.1.3/hidden_info.htm or 192.168.1.1/debug.htm
192.168.1.2/debug.htm or 192.168.1.3/debug.htm
I've looked everywhere and cannot find a fix. Any help will be appreciated.
However I can access and login to the following: ...
Please be a little bit more verbose. What happens, why do you think you can't login? Any messages, any screenshots, ....?
- MstrbigMaster
Hmmm… can't reach this page
It looks like the webpage at https://192.168.1.1/ might be having issues, or it may have moved permanently to a new web address.
Interesting. Has the latest hack somebody tried on the consumer routers with some wannabee-sso-like-code in qa-quality made it over to the Orbi Pro? What I have in mind is this wonderful *****. Does this look familiar what might go on under the hood there?
- ReneDNETGEAR Moderator
Hello Mstrbig,
And welcome to the NETGEAR Community! 🙂
There is an ongoing issue for Orbi routers pertaining to certificate error and affected browsers are both Edge and Google Chrome. Netgear Engineering team plans to release a firmware that fixes this issue soon but there is no ETA. For now you can use a patch firmware that fixes this issue. YOu may want to try to visit the link below to get the patch firmware and load it to your router. The step by step procedure are already mentioned in there as well.
Have a lovely day,
Rene D
Netgear Team
