t_bone_39
Dec 10, 2025Follower
I have the Net Gear Orbi SRR660
I have the Net Gear Orbi SRR660. This system has 3 wireless networks. The main network supports both 2.4 and 5Ghz. Wireless network 2 allows me to have a separate SSID for the 2.4 and 5Ghz bands. ...
Dec 10, 2025Guru - Experienced User
The Orbi Pro line is now EoL. So no new features or major FW updates will be forth coming.
Support and End of Service FAQ | NETGEAR Communities
The 60 series was a WiFi5 only supporting system. You can just add WiFi 6/7 to a system. All that entails getting newer hardware. So if you want WiFi6/7 support you'll need a new generation MESH system. Newer Orbi home supports WiFi7 and 7 and a separate IoT network for those IoT devices needing 2.4Ghz only support. The main WLAN remains a signal network only and can't be separated.
