Pikadilli
Jul 16, 2026Follower
I have to adjust Port Forwarding but can't find the settings
I have a similar issue. Due to changes at work where they added ZScaler, I have to adjust Port Forwarding but can't find the settings
Please read the existing comments and figure out what might be missing for your story...
Hint: RT*M:
https://www.downloads.netgear.com/files/GDC/SXK80/Orbi_Pro_WiFi_6_UM_EN.pdf
p.204 FF. Port Forward
This was the original thread I was referring to:
Port forwarding config is also available on Netgear Insight, certainly on the Insight Cloud portal:
https://kb.netgear.com/000065750/How-Do-I-Create-a-Firewall-Rule-in-the-Insight-Web-Portal
Guess a moderator had split the discussion from the original thread, this made it impossible refering to the similar issue you had referred to
