Pikadilli
Jul 16, 2026Follower
I have to adjust Port Forwarding but can't find the settings
I have a similar issue. Due to changes at work where they added ZScaler, I have to adjust Port Forwarding but can't find the settings
Port forwarding config is also available on Netgear Insight, certainly on the Insight Cloud portal:
https://kb.netgear.com/000065750/How-Do-I-Create-a-Firewall-Rule-in-the-Insight-Web-Portal
Guess a moderator had split the discussion from the original thread, this made it impossible refering to the similar issue you had referred to
Please read the existing comments and figure out what might be missing for your story...
Hint: RT*M:
https://www.downloads.netgear.com/files/GDC/SXK80/Orbi_Pro_WiFi_6_UM_EN.pdf
p.204 FF. Port Forward
This was the original thread I was referring to:
