vjbutt
Jan 12, 2024Aspirant
Intermittent connection issues with SXS30
My setup is the following. I have a SXR30 router connected to two SXS30 satellites both over a wired connection. All three devices are running the latest firmware (V4.3.3.106). Intermittently,...
Jan 12, 2024Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
Try:
Enable MU-MIMO - Enabled
Enable Fast Roaming - Enabled
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Also enable this as well:
vjbutt
Jan 16, 2024Aspirant
FURRYe38 thank you for taking the time to reply to my query.
> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Technicolor TG789vac V2
200 m^2 = 2153 sq ft
> What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS ️ to begin with depending upon building materials when wired or wirelessly connected.
8.68m = 29 feet and 20.16m = 66 feet. These are as the crow-flies distances and in reality there are several thick limestone walls in between. Without the satellites WiFi signal directly from the router is very weak resulting in less than 15 Mb/s connection speeds. Also 5GHz will not work without satellites, since transmission through obstacles is not very good at this frequency.
3-4 2.4GHz networks in the neighbourhood, but none at 5GHz, which is the frequency that I set my devices to connect to if possible.
>Try:
I already had these enabled, but these were the first settings that I disabled when I had these problems since they are more exotic ones which may actually hinder getting a connection in the first place.
> https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
My problem is not just on Apple devices, but a multitude of different devices.
I believe that these are for WiFi 6 devices. But I haven't experimented with these since these do not appear in the main setup pages, and only appear in the debug page (so well hidden from normal users). I can try setting these to enabled. But I doubt that it will solve my problem.
- FURRYe38Jan 16, 2024Guru - Experienced User
What mode is the modem working in? Router or Bridge mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...> What is the size of your home? Sq Ft?
If you think building materials are causing problems then I would move the SXS closer to the SXR as we already know, building materials can cause problems and inhibit good signal travel.
What channels are being used currently?
>Try:
> https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...My problem is not just on Apple devices, but a multitude of different devices.
Will not hurt to try this feature. I have this enabled on my SXK30 system. Worked great for my devices. WiFi 5 and 6 devices.
