brkeogh
Sep 19, 2025Follower
Is AX1800 compatible with AX1800 pro satellite?
Hi! I have an AX1800 mesh setup in my house. I need one more satellite but the AX1800 satellites are only sold in 2-packs or 3-packs. The 'Pro mini' satellites seem to be sold in single packs. D...
Nov 08, 2025Guru - Experienced User
There's a compatability guide for the consumer orbi's: https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
And then the pro orbi's: https://kb.netgear.com/000065558/
you can't mix the pro's and the consumer.
