FoxyFoxster
Mar 23, 2024Aspirant
log in on router SXR30 do NOT work anymore
I wanted to enter my router via 192.168.1.1 (edge browser) and then I get a page with the message the page is not assesible, there may be problems or the page is moved...(translation from DUTCH) E...
- Mar 28, 2024
Hello FoxyFoxster,
And welcome to the NETGEAR Community! 🙂
This is already an ongoing issue and there is a patch firmware that fixes this. The official firmware is on its way but we do not have ETA on it. Please download the beta firmware on the link provided below and load it to your router and satellite. You can use a firefox browser to login to your GUI and load the firmware provided as a workaround for now. After loading the firmware, a full factory default is necessary on the router, then you test if you can use Chrome or Edge after.
SXR30
SXS30
Take note to update the satellite firmware first before the router. You may want to also check the link below related to your issue.
Have a lovely day,
Rene D
Netgear Team
schumaku
Mar 26, 2024Guru - Experienced User
Start about there https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/Chrome-Certificate/m-p/2371124/highlight/true#M6882 - manually update the satellites first, and then the router.
