FoxyFoxster
Mar 23, 2024Aspirant
log in on router SXR30 do NOT work anymore
I wanted to enter my router via 192.168.1.1 (edge browser) and then I get a page with the message the page is not assesible, there may be problems or the page is moved...(translation from DUTCH) E...
- Mar 28, 2024
Hello FoxyFoxster,
And welcome to the NETGEAR Community! 🙂
This is already an ongoing issue and there is a patch firmware that fixes this. The official firmware is on its way but we do not have ETA on it. Please download the beta firmware on the link provided below and load it to your router and satellite. You can use a firefox browser to login to your GUI and load the firmware provided as a workaround for now. After loading the firmware, a full factory default is necessary on the router, then you test if you can use Chrome or Edge after.
SXR30
SXS30
Take note to update the satellite firmware first before the router. You may want to also check the link below related to your issue.
Have a lovely day,
Rene D
Netgear Team
FoxyFoxster
Mar 28, 2024Aspirant
Thx for reply.
I have read the entire item. I am disappointed in Netgear that they don't do anything about the problem and you have to pay for an intervention if you want to introduce a problem. If a need a new system (within a few ...) then i doubt I take netgear, which is not the cheapest system.
I hope that there will be a fix soon
Greetings and thx for reply
schumaku
Mar 28, 2024Guru - Experienced User
Can't follow you. Netgear offers a fix firmware for the SXS30 satellites and SXR30 - ready to download and deploy to your deices. That's not "nothing".
Curious, what does hold you off from deploying what is readily available for (some weeks in fact)?
What exactly do you expect from a potentially paid intervention?
From what I understand (and that's a little bit more than nothing), the issue is caused by some magic (*****) ideas some Web browser makers introduced to their code and requirements. Ways outside of Netgear....
Unfortunately, you don't say us what systems, what platforms, what operating, system, and what browser you are using in your environment. This is what makes us community members (this is what we are, most of us are not Netgear) impossible to help you any further.
