Feb 14, 2022Guide
Mesh link status
Hello,
I have the OrbI PRO Wi-Fi 6 mini model SXR 30 and two satellites SXS 30.
I have them connected via ethernet backhaul. On the Insight app it shows the Mesh link status as excellent. However, I thought I remembered previously to firmware updates that the mesh link status read ethernet when connected via ethernet backhaul.
Thanks for any help.
I have the same setup (SXK30) with a wired backhaul. Mine shows the same "excellent" in green in the app. It is wired and runs as wired so I think its just how the app displays it.
- 7474GuideThank you for taking the time to reply.
I believe mine is running as intended as well and it is nice to hear that yours is showing the same and running as expected.
I have found that removing the Ethernet cable changes the link status to GOOD. With a return to excellent with reconnecting the Ethernet cable.
Just thought it used to show Ethernet prior to all of the firmware and app updates.
Thanks again.- plemansGuru - Experienced User
I'm honestly not sure what it said before. I'm not a huge fan of the insight app as it takes so long to load so I rarely use it.
I mainly just log in through the gui
