coolgreany
Jun 04, 2022Guide
Mine was stable again for about a week and then started disconnecting
Same here. Mine was stable again for about a week and then started disconnecting at least daily and sometimes several times a day. As soon as I get back from my trip I'm swapping it out for a TP l...
coolgreany
Jun 12, 2022Guide
I'm using a spectrum modem E31T2V1.
The Orbi is using the latest firmware version 4.2.0.122. I also tried going back to the previous firmware version as mentioned in the other discussion but that did not resolve the problem.
Jun 12, 2022Guru - Experienced User
What is the CAT# cable in between the SXR and ISP Modem? CAT6 is recommended.
Does the front LED turn on PINK when the SXR seems to stop working?
- coolgreanyJun 12, 2022GuideFURRYe38 I'm not physically with the router now so can't check the cable. However, I did swap it out initially when this all started happening.
Yes, as stated in this discussion and the discussion I started in March, the front LED of the Orbi router turns PINK (or magenta depending on your color palette) when the SXR disconnects.
Once again, it has now been stable for 5 days without any disconnect. Randomly it disconnects daily or several times a day or every few weeks. The longest it has been stable in its current configuration is 3 weeks.- FURRYe38Jun 12, 2022Guru - Experienced User
Something to check with the ISP modem and see. If the ISP modem causes problems or looses it's services, this could be seen by the SXR.
- coolgreanyJun 12, 2022GuideI understand. I already contacted spectrum and the started happening and everything appeared normal with the modem. The modem doesn't appear to lose internet connection when the router disconnects.
