josueortiz's avatar
josueortiz
Follower
Oct 31, 2022
NETGEAR Orbi Pro WiFi 6 AX540 SXK50B3
Is there a way to have a captive portal prompt with username and email using Orbi Pro WiFi 6 AX540 SXK50B3? I read the user manual under the Set up a guest WiFi network with a captive portal section, but it seems that you can only use or upload txt file with the terms and conditions and an a logo image.
No RepliesBe the first to reply
ProSupport for Business
