Synica1
Sep 28, 2022Guide
New firmware nuked Insight and the web portal from SXR80
Hey all. Been a week, and the last thing I wanted to do was muck around with our WiFi. New firmware (4.2.2.130) has apparently nuked all management connectivity to our SXR80. Insight insists it's ...
Synica1
Sep 29, 2022Guide
Starting to think it may be more hardware than firmware related. Case # 46515679 submitted.
Following the recommended steps in the initial response I received, was attempting to manually downgrade the firmware from 4.2.2.130 to 4.2.1.120, to see if the results were similar. Since I couldn't access the router interface, started off by unplugging the wired backhaul, connecting directly to LAN port 4, and used the hard reset button. Once the setup screen came up, opened a second tab and turned on debug capture. Proceeded through the setup (NOTE: had to take a short 5-7 minute break while it applied SSID and user/password settings); once I got to the basic home screen, swapped to the advanced tab, and switched WAN from the 2.5G to 1Gb (LAN 2) port. Gave it 2-3 minutes to settle down, and it appeared to recognize the port, LED went dark for normal operation, etc. Went to Firmware Update, manual tab, selected the IMG for 4.2.1.120, but before I could hit "UPLOAD," that frame blanked out and came back up with an "error, network status reset." I looked up just in time to see the LED illuminate in white and slowly "sputter" out (not like the normal slow fade when it's trying to sync w/a satellite or during startup). This would have been about 10-15 minutes from when it was reset. I let it sit for about 10-15 minutes while handling some stuff for work, came back, and the magenta light was back on.
Unplugged everything except my troubleshooting tablet, let it sit (again) for about 15 minutes. Reconnected power only (not WAN), and the magenta light comes on about 2 minutes and 15 seconds after power on. Can't get to the debug tab, router interface, nothing.
If I reset it again, I'm worried the debug capture is going to get wiped. Anyone know if that's indeed true?
Thanks,
Ben
- DaneASep 29, 2022NETGEAR Employee Retired
Yes, it will be wiped out. However, you can start the debug capture again once the SXR80 has been setup.
Regards,DaneA
NETGEAR Community Team- Synica1Sep 29, 2022Guide
Took 3 tries, but finally got it downgraded to firmware v4.2.1.120. Of course, as soon as I plugged the WAN connection in and it reached out to Insight... it went back down. Insight showed it as "configuring," and had (I think) tried upgrading to the current firmware again.
It's now completely removed from Insight. Giving it (and myself) a bit of time to cool down, before I reset it (for the nth time), and try again.
Final update (no, unfortunately it's not fixed):
Successfully downgraded the firmware again to 4.2.1.120. I'm able to get through most of the configuration, connect the satellite via wired backhaul on the 2.5G port... but as soon as I attempt to switch from Router to AP mode, everything goes sideways, and we're back to the land of magenta lights. Can't connect to the router interface via wireless or direct connection to the LAN ports.
I've put enough time into trying to fix this. Will research alternatives and wait for the support team to respond to my ticket.
