WayneU's avatar
WayneU
No Internet via LAN
I own a NETGEAR Orbi Pro AC3000 Business Mesh WiFi System, 2-Pack, Wireless Access Point (SRK60) and cannot access the internet via ethernet hard-wired LAN. I have a multitude of wireless devices...
  • WayneU's avatar
    WayneU
    Nov 01, 2018
    Because I was spending far too much time on this problem, I fixed it, but in an unconventional way.  I remembered taht I had an older ASUS router, and I set it up as a DHCP server.  I then turned off the ASUS WiFi radios, and connected all of my LAN lines to the ASUS router.
    Next, I reconfigured the Netgear Orbi Router to be a plain and simple WiFi access point that is plugged into the ASUS router.  I now can do everything I need to do over the LAN.  And I have very good WiFi via the Orbi.  Thank you RaghuHR for your help.  I sincerely appreciate that you were willing to go the extra mile with me to figure things out.  But I now consider the problem fixed.
ProSupport for Business
