WayneU
Oct 25, 2018Aspirant
No Internet via LAN
I own a NETGEAR Orbi Pro AC3000 Business Mesh WiFi System, 2-Pack, Wireless Access Point (SRK60) and cannot access the internet via ethernet hard-wired LAN. I have a multitude of wireless devices...
- Nov 01, 2018
Because I was spending far too much time on this problem, I fixed it, but in an unconventional way. I remembered taht I had an older ASUS router, and I set it up as a DHCP server. I then turned off the ASUS WiFi radios, and connected all of my LAN lines to the ASUS router.
Next, I reconfigured the Netgear Orbi Router to be a plain and simple WiFi access point that is plugged into the ASUS router. I now can do everything I need to do over the LAN. And I have very good WiFi via the Orbi. Thank you RaghuHR for your help. I sincerely appreciate that you were willing to go the extra mile with me to figure things out. But I now consider the problem fixed.
WayneU
Oct 31, 2018Aspirant
Hi Raghu,
I sincerely appreciate your screenshot, but apparently your screenshot is from a very different version of Mac OSX than I am running. I am running High Sierra, and I simply do not have the same options as the ones that you are showing. First, my router has an IP address of 192.168.1.1. When I go to Preferences->Network and select the LAN card that I want to configure, I can select DHCP for Configuring IPv4, but I do not have the option of setting the Router address if DHCP is selected. When I select the "Advanced..." button, I can type in a DNS Server, and since my Router address is 192.168.1.1, that is what I type in for DNS. But I seem to get a very weird IP address from the DHCP that does not start out with 192.168... Here is a screenshot of what I get when I select DHCP:
Next, I tried using DHCP with a manual address in an attempt to force a 192.168.1.xx address, but I still do not have the option of setting the Router address under High Sierra.
Neither of the two options shown to you allow for internet access via LAN.
WayneU
Nov 01, 2018Aspirant
- RaghuHRNov 01, 2018NETGEAR Expert
Hi WayneU
Let me take this opportunity to thank you for choosing Orbi Pro. We are proud to welcome satisfied customer and look forward to many years of working together.
If you have any questions about our Orbi Pr, you can reach us here, and we will be happy to assist you.
Once again, thank you.
Have a nice day,
Raghu
