lostman
Jan 16, 2021Initiate
Orbi app cannot connect to Orbi router
Model SRR60 IOS version: 14.3 App version: 2.7.6.3 Router firmware version: 2.6.0.108 My ORBI app cannot connect to my ORBI router. As suggested in other threads, I have deleted any nighthawk/...
Kmac40
Feb 02, 2021Aspirant
This has been frustrating me for weeks and I finally got it o work. I did not have Netgear armor activated (bit defender) so I reinstalled that app. At first it was not connecting, 2 access points were available and it was auto-connecting to the one just listed as “armor”. I manually switched it to “Netgear armor” and it connected right away.
Then I went back into the Orbi app and it finally worked:)
Good luck!
Good luck!
Kmac40
* Forgot to say (though I doubt this had anything to do with it) the only other setting I fiddled with prior to the Orbi app being able to connect to router again was on my iPhone, under date/time. There is is something called “24 hr time” that I enabled. Then I turned on Armor and it worked. Thought it may be worth mentioning because because I had issues with my Blink cameras being able to go on “live” view. After I checked the Orbi app and it was working, I went into the Blink app and the live view was working as well. Hope that helps!
