Sisaket's avatar
Sisaket
Orbi iOS app?
Hi I have an orbi pro and an outdoor satellite When I go to the devices I cannot pause or resume, all the toggles are just greyed out Any ideas
  • JohnC_V's avatar
    JohnC_V
    Mar 26, 2018
    Sisaket,
    Well, the Orbi is not your main router and it is just a wireless provider for your network. Definitely, it cannot pause / block anything or even do anything as it only provides wifi.
    If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
