Sisaket
Mar 20, 2018Aspirant
Orbi iOS app?
Hi I have an orbi pro and an outdoor satellite When I go to the devices I cannot pause or resume, all the toggles are just greyed out Any ideas
- Mar 26, 2018
Well, the Orbi is not your main router and it is just a wireless provider for your network. Definitely, it cannot pause / block anything or even do anything as it only provides wifi.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
JohnC_V
Mar 22, 2018NETGEAR Employee Retired
Hi Sisaket,
Welcome to our community! :)
May you be able to send us a screenshot for better understanding of your issue. Thanks in advance!
Sisaket
Mar 22, 2018Aspirant
- JohnC_VMar 23, 2018NETGEAR Employee Retired
Please try enabling the Access Control then check if you can now pause / resume the wireless devices.
Here is the manual for reference.
- SisaketMar 23, 2018Aspirant
Thanks for your help, but this is the reply from Netgear.
When the Orbi is used in AP mode, unfortunately the block/unblock functionality is not supported by the device, and is ultimately deferred to the connected router that is acting as the DHCP server
- JohnC_VMar 26, 2018NETGEAR Employee Retired
